ran my water heater on electric for about 2 weeks. no problems. then...no hot water. switched to gas and works fine. back to electric, no hot water. ran on gas for another 3 weeks just fine. Bad ele...
Assuming everything is turned on, switch at the heater, breaker, etc. most likely you burned out the 120v heating element. We found out the hard way that turning the heater on for just a few seconds is enough to fry it.
Its a very easy fix, $20-$30 for the replacement element depending on the type of tank.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
