Hamnet's avatar
Hamnet
Water heater switch
I just changed out my interior water heater paddle switch. I swear I did just like the old one. I was running a small fan from the kitchen gfi plug, when I switched the water heater on the fan speed slowed, turned it off and went back to normal speed. I used one of the household tester and the lights on the tester said "hot & nuetral switched". The switch tells what side black and white wires go on. I am connected to power supply. Need help. Thanks
  • If the switch is a 120V AC switch you did get another 120V AC switch and not a 12V DC switch?
  • Make and model of water heater?
    Is there an exterior maintenance switch?
    I am guessing you may have an element going to ground.
    What type of shore power? 30/50? What type of receptacle are you plugged into?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Two switches that LOOK alike, might not be.. Do you have the switch specifications handy where you can post them.
    Or failing that a photo of the REAR of the switch.
  • I am connected to power from my house which I always do when parked at my house. I have a seperate outlet for the RV. I am baffled, never had an issue until I changed out the switch. I must admit we haven't used the switch for a couple years because it didn't work. The water works fine when using propane.
  • Maybe it has a better connection and now pulling more amps than it use to so you are seeing the diff.
    Or if it is a suburban hwh the wires are loose in the box and are arcing some it does happen
  • Black and white wires? Is this the switch for a 120 volt element in your water heater?
    Could be loose connection in the system.
    You may have extremely low voltage where you are connected to shore power.
  • If there are only two wires to the switch, you can't do it wrong.
    Suspect poor electrical connection somewhere else.
