dougrainer
Jul 18, 2014Nomad
The outside switch is ONLY for 120. It is usually a winterizing switch. Turn it OFF when you drain the W/H to prevent dry firing when it is empty. If you have an inside switch, the outside switch must be ON for the inside switch to work. Doug
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
