Bumpyroad
Jul 18, 2014Explorer
Ron3rd wrote:dougrainer wrote:
The outside switch is ONLY for 120. It is usually a winterizing switch. Turn it OFF when you drain the W/H to prevent dry firing when it is empty. If you have an inside switch, the outside switch must be ON for the inside switch to work. Doug
Doug, on my new trailer, I only have 1 inside switch for propane, and I have the outside switch inside the heater's cover for 120v. The switch is kind of hidden and not easily seen.
if that's an atwood 6 gallon wh I would appreciate a road map to it.
bumpy
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
