Ron3rd
Jul 18, 2014Explorer III
Bumpyroad wrote:Ron3rd wrote:dougrainer wrote:
The outside switch is ONLY for 120. It is usually a winterizing switch. Turn it OFF when you drain the W/H to prevent dry firing when it is empty. If you have an inside switch, the outside switch must be ON for the inside switch to work. Doug
Doug, on my new trailer, I only have 1 inside switch for propane, and I have the outside switch inside the heater's cover for 120v. The switch is kind of hidden and not easily seen.
if that's an atwood 6 gallon wh I would appreciate a road map to it.
bumpy
It is a 6 gal Atwood, I had to look in the manual to find it. It's buried behind some wires as I recall. You can't actually open the cover and just see it. It's a black rocker switch. Odd that they put it where they do and not on the panel inside.
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
