Old-Biscuit
Jul 18, 2014Explorer III
Atwood.......2003 and earlier models
AC switch on box/cover over element on backside of tank along with the set of t-stats for element. Propane t-stats in outside compartment with an ON/OFF switch on panel inside RV.
After 2004......
AC & Propane ON/OFF switches inside RV on panel
One set of t-stats for both electric/propane in outside compartment
Electric element still on backside of tank (under a cover with a DC relay-----uses DC to activate the AC to element)
Suburban \
AC element in outside compartment
AC ON/OFF rocker switch in outside compartment (may also have another AC ON/OFF switch inside RV...both have to be ON for electric)
Propane ON/OFF switch inside RV on panel
Separate set of t-stats in outside compartment
One 120V AC set and one 12V DC set...under cover with 'push to reset' on cover (resets HI temp t-stat if it trips)
After 2004......
Suburban \
