pewterman20ExplorerJul 18, 2014Water heater switchIs the outside switch on the water heater only for the propane ignition, or does it control the electric as well? I have inside switches for each of these.
BumpyroadExplorerJul 19, 2014ChooChooMan74 wrote:Mine has only an external switch. I wired in my own switch Here. so you did all the wiring at the junction box, no where near the WH. I'll have to check that out.bumpy
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Atwood water heater problemSwitching toiletsWater Heater Replacement RecommendationsWater Heater Leak on start up.
