Lynnmor wrote:
Check the temperature at the faucet that is closest to the water heater. If it is too hot, simply replace the thermostat. Videos available on Youtube.
Thanks,
I was able to see on YouTube how to remove the thermostat.
Dyers sells a 120, 130, and 140 degree model of the thermostat. I was able to determine that I had the 130. I ordered the 120 below:
http://www.dyersonline.com/suburban-water-heater-520788-thermostat-limit-assembly-120-degrees-120v.htmlNow maybe I can turn the hot all the way up during a shower.
