Old-Biscuit
Oct 13, 2016Explorer III
smg2014 wrote:
Yes I agree that new service dep't is needed but we are limited to RV Care dealers under warranty and closest is 2 1/2 hours away. Atwood brand, not Suburban. Good info Doug, thanks. Called Atwood and they say to replace ignition board.
Atwood uses the same set of t-stats for propane AND electric.
T-stat (Brown wires) is normal temp t-stat that opens at 140*F
ECO (Red wires) is Energy Cut Off High temp t-stat that opens at 180*F
Hard to swap them cause they have different size spade terminals (ECO---large spades & t-stat ----small spades)
IF the electric heats and shuts off properly (doesn't over heat) then the set of t-stats are working and would do same when propane is used.
Circuit board controls both electric and propane functions
When using electric a milivolt signal goes thru ECO to gas valve so that ECO is in control circuit (if it opens milivolt signal lost and electric heating is stopped)
When using propane full 12V Voltage goes thru ECO to gas valve.
When t-stat opens 12V is secured to ECO circuit and gas valve closes.
Measure water temps on electric/propane
When water reaches 140*F the T-stat OPENS and DC to circuit board stops to rest of circuits
When water temp reaches 110*F or less then T-stat CLOSES and DC continues to rest of circuits allowing reheating
(Same on electric or propane)
S/B DC on top connector anytime either switch is ON
No DC on bottom connector anytime T-stat OPENS
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
