smg2014's avatar
smg2014
Water heater won't cut out on propane
We have a 2014 Jayco 5th wheel. The 10 gallon water heater has never worked on propane since we bought it. It will not cut out and the first time we tried it on propane, the safety blew. We have had it in three times and it still does not cut out. They have cleaned all wires etc. and have replaced the thermostat as well as the relay. Now I am being told they don't know what to do. Unit is still under warranty until May 2017 and we want this fixed, Any recommendations would be greatly appreciated.
  • Brand?
    If it's a Suburban the first thing I would do is replace the 12 volt side hi limit switch pack. That is what controls temp settings. Does it run until the water boils? Or is the pressure relief just popping off. Could be a faulty relief valve.
