MPD56
Jun 07, 2013Explorer
If it is an Atwood, I would suspect a dirty or cracked spark probe assembly? In the manual it will tell you how to check the integrity of the spark probe. If you can hear the spark then I wouldn’t suspect a bad board. Basically when it is dry out, you turn the gas off and insert an insulating material between the sparking and ground probe gap and this might force the spark to jump where it would if it is damp out? If you do it when it is dark out, it would be easier to see the spark.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
