dano73 wrote:
OB, we're talking electric, not propane, red fault light for electric, where is that located?? Like I said I've owned many rvs and yes the t-stat is installed right. I will try to test the temp of the water at the prv without getting scalded, and the air pocket is there, its one of the first things I checked. And the prv isn't leaking, its spraying everywhere, and is that a home depot part??
The same RED fault light that comes on when propane fails will also come on electric when ECO Opens.
The t-stats (normal & ECO either work or don't)
PRV....can get them at hardware....just need to be sure same thread size.
IF PRV is bad......water is scalding hot above 125*F. And will steam thru a leaking PRV.
