Old-Biscuit
May 08, 2021Explorer III
Check that the High Voltage wiring (large Orange wire) is not being pitched when you close access panel....shorting to ground
Does the AC Element heat to temp with access panel closed?
*DEL uses DC to control AC & Gas
