enblethen
May 09, 2021Nomad
Check for a good ground.
The gas valve coils have a ground connection behind the gas valve.
There is a ground coming through the wiring harness as well.
I cleaned the valve ground and connected the harness ground to it with a short piece of #14 SAE black wire
Did you clean the contacts on the circuit board?
