Gdetrailer
May 14, 2021Explorer III
23hotrodr wrote:dougrainer wrote:23hotrodr wrote:Timeking wrote:
"The RETURN millivolt signal for flame is NOT that strong and will be disrupted by a slight short to ground." Return signal? Are you saying that the Suburban design uses the spark apparatus as double duty for whether or not the flame lit? If true, that seems dumb.
There does not appear to be any damage to the orange wire, looks new. The connection to the lug is shiny and clean.
As suggested, I cleaned the burner tube. The air-gas mixture is fixed, not adjustable.
--- Are you positive the air mixture is not adjustable? On all RV WHs I've seen, there is a mixture adjustment where the burner tube meets the gas valve. You adjust it by loosening a small screw and twisting it on the tube to open or close the slots in it to add or block air.
Whenever I see a statement like this, I ask the question-----How long have you been working on RV Water heaters and/or RV's ? Because you are wrong. Doug
PS, I have seen a LOT more RV WH'ers than you(thousands):B
Thank you doug for putting me in my place. I have always appreciated the time you take and the expert advice you have given to help others over the years. I was simply trying to help by offering a small suggestion that might possibly have been overlooked. I in no way was trying to compete with you and your expertise. You are even more correct when you state you have seen 1,000s more WHs than I have since I am totally blind and have really never "seen" a single one. All I have done for many years is do virtually all the maintenance and repairs on my own MH and helped a few others find and fix problems with theirs. I have also had to repair things that the professional RV techs either screwed up or outright destroyed on my MH the few times I took it to them for repairs I thought were beyond my capabilities. I am extremely sorry for having tried to help with this issue, since I am obviously ignorant. I always look forward to hearing your advice to others and have learned from it numerous times. Best regards- Mick
Don't feel too bad, I had a much older pilot light Suburban from the 1980s, I do believe it did have a adjustable shutter..
But, dig some digging and found a photo of the newer DSI Suburbans and Doug is correct.
Found that photo HERE
So, there is no shutter to adjust, no way to compensate for altitudes other than changing the jet.
Stock is setup with a jet for 4500 ft elevation, anything higher than requires a new jet..
The OPs issue has to be boiling down to not correct fuel for the air which could be a partially blocked jet..
