joe0508ExplorerApr 07, 2014water heaterI have an instant hot water spout on my sink in my motorhome.I hooked it up and after about 10 min i noticed the hot water started to come out of the spout all on its own.I instantly unplugged it.I lo...Show More
Old-BiscuitExplorer IIIApr 07, 2014Replace with a brass swing check valve.The check valve on WH is plastic plunger/spring & O-ring. It is inside the nipple on WH tank.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
