Recently our Suburban water Heater just stopped. Gas function still works perfectly. I checked the breakers,pulled the heating element, checked the reset control(doesn't seem to be any problems). The ...
Not uncommon for the temp sensor pack to burn out. Also with Suburbans its not uncommon for it to burn wires, or the little switch down on the bottom left side. You need a volt meter to start tracing wires.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
