Thanks guys. "Over There",I'm not a super tech with these issues but rather a jack of all trades etc. Foolishly started at the element and worked my way back. I removed the element and did a test on it. then put it back in checked the voltage to it. None,then pulled the reset out and checked them. looked good and not tripped. "donn0128",I did notice that the little switch on the bottom left looks baked and it with not switch on and off. Stuck in the on position. Feels and looks like it might be cooked. Never taken one out. Does it just pop out with a thin screwdriver? It doesn't seem to have any other access. If that is the problem, does that interrupt power to the element? Thanks again
