TGO
Aug 03, 2017Explorer
Water Heater
Recently our Suburban water Heater just stopped. Gas function still works perfectly. I checked the breakers,pulled the heating element, checked the reset control(doesn't seem to be any problems). The ...
j-d wrote:rk911 wrote:
...bad thermal cutoff (TC) essentially a fusible link that protects the heater from a flashback....
Above info and picture are for an Atwood water heater. OP says his is Suburban. They don't use that fusible link. Maybe should, but they don't.
OP - Can you furnish the Model of this Suburban? Should be visible from outside, lower right corner of the mounting frame.
