cpaulsenExplorer IIDec 23, 2019water heaterSububran water will not ignite when on propane....electric portion works fine.....and yes...I do have propane
rk911ExplorerDec 23, 2019will the stove light? if so let the burners burn for about 30-seconds and try again. you may have air in the line.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSmelly Water HeaterWater pump?Suburban SW12DEL Water Heater On/OFF switch melts???
