rk911 wrote:
will the stove light? if so let the burners burn for about 30-seconds and try again. you may have air in the line.
I keep hearing this but frankly.. Think about it. Stove sips propane. Water heater guzzles it. (Same for Furnace) Water heater will try 3 times before it locks out.. You'd need like 100 feet of line full of air or more before the first two attempts would not purge.
But that said.. Won't hurt to light the stove as that confirms the propane system is indeed working.
To the O/P. You need to observe while someone else turns it on.
Does it light, go out re-light (three times no relight the 3rd time)
Does the thing make sparks (Snap SNap) but no ignition
Does it just sit there like it was turned off.
Once we know that we can get more specific.
