All stove burners light....turn the gas water switch on......does not attempt to light.....red light does not come on. Have pretty much figured out the control board is bad. Did try the reset........no luck there also. Will order a new control board.2018 Montana HC...2 years old. Thinking the board is behind the convenience center.....will clean the basement storage out so I can remove the panel out so I can see if it is back there.
