cpaulsenExplorer IIDec 23, 2019water heaterSububran water will not ignite when on propane....electric portion works fine.....and yes...I do have propane
Old-BiscuitExplorer IIIDec 26, 2019Suburban uses separate set of T_stats for electric and propane.Both sets are 'pre-set for same temps (t-stat Opens at 130*F and closes at 100*F)So if temp is 'hot' (100*F-130*F) both t-stats will be open and no heating from either source will occur.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSmelly Water HeaterWater pump?Suburban SW12DEL Water Heater On/OFF switch melts???
