Now that I've located and fixed a leak in the corner of my slide out, I've found another water issue... There is some kind of leak near my shower. I can't tell if it's coming from outside or inside. T...
Thanks for taking a look at my post! That's the strange part: the drain and fresh water lines that run under the shower appear to be dry. The water is somehow getting between the linoleum and floorboards. Sometimes the drip edge around the shower gets a little water in it, but seemingly not enough to cause this. This is more like bulk water damage without a source.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
