Now that I've located and fixed a leak in the corner of my slide out, I've found another water issue... There is some kind of leak near my shower. I can't tell if it's coming from outside or inside. T...
In my case I was able to take care of the leak in my rv that was created by excessive water pressure that overcame the ability of the screw on connector on the water line which was not readily accessible. Dropped the pressure to about 40 psi and not a leak since over a period of 3 years.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
