Now that I've located and fixed a leak in the corner of my slide out, I've found another water issue... There is some kind of leak near my shower. I can't tell if it's coming from outside or inside. T...
The drain in the shower has been posted a number of times on this Forum as a potential leak point. If the pipe leaks where it attaches to the shower pan, water can run on the underneath surface of the pan and cause havoc.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
