Now that I've located and fixed a leak in the corner of my slide out, I've found another water issue... There is some kind of leak near my shower. I can't tell if it's coming from outside or inside. T...
Thanks for everyone's thoughts on this! I've inspected the drain connection to the shower pan, and looked around underneath the shower pan, but everything's dry. Likewise, there aren't any visible leaks in the water lines that run under the shower.
I finally bought an inexpensive USB borescope to take a closer look. At less than $20, I figured it was worth a try before damaging the linoleum to get underneath it. I'll post how well the borescope works.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
