BFL13
Aug 15, 2013Explorer II
The toilet sits on a flange, held down with two bolts. There is a seal (foam or wax) that goes between the flange and the bottom of the toilet.
You could have loose bolts, a bad seal, or a broken flange from over-tightening the bolts. Whatever, you need to shut off the water supply to the toilet, undo the bolts, lift off the toilet, and find out what is wrong, then fix it.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 21, 2026
