rockhillmanor
May 29, 2013Explorer II
Lynnmor wrote:John S wrote:
We had a rainy weekend in Central IL this holiday weekend. All was okay until we started getting water dripping from our wineguard batwing TV antenna handle inside the motorhome. I looked at the caulking around the antenna base on the roof and it looks pretty good. Is there any seal or something in the antenna housing that might need replacing or ??? Would appreciate any and all suggestions and ideas.
Thanks, John S.
Had a problem as well. Washers were missing from elevating shaft, Boot was messed up with sealant. Sealant didn't stick to aluminum base. Putty tape failed. See:
Antenna Leak
Wow, you sure did a nice job on that DIY!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
