Lynnmor
Jun 10, 2013Explorer II
John S wrote:
Darn, the decor sealant did NOT solve the problem. I still get water leaking through the antenna handle inside the motor home. What should I try next?
In this order:
Recheck cable boot, it can pop off. Seal boot with adhesive silicone.
Replace quad seal on elevating shaft.
Replace seal under 15/16" nut from inside.
Pull antenna from roof and replace sealant tape, then caulk with Dicor when done.
I did all of the above and it needed everything but the seal under the 15/16" nut.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
