LarryJM
Jun 10, 2013Explorer II
John S wrote:
Darn, the decor sealant did NOT solve the problem. I still get water leaking through the antenna handle inside the motor home. What should I try next?
From page 5 of the manual HERE
LUBRICATING RUBBER QUAD RING
Lubricate rubber quad ring on elevating
shaft which is below worm gear with
silicone spray lubricant at least twice
yearly. This will keep quad ring from
becoming brittle which could result
in leaks down elevating shaft. Refer
to page 7 for removing worm gear
assembly. Item #7 on parts explosion.
Larry
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
