Hi all, I'm hoping you can help me out with this problem I'm having. I've got an Arctic Fox 31D and the hose behind the city water connection is leaking. The one inside the rig. I'm pretty sure I ...
I see them. Normally just tightening the collar of the fitting will keep it from leaking. If that doesn't work then you could take it apart and see if something looks wrong (Dont use any sealer or tape on the compression side). You could also very cleanly cut if off and replace the fitting with a Shark-Bite fitting from someplace like Home depot.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
