Hi all, I'm hoping you can help me out with this problem I'm having. I've got an Arctic Fox 31D and the hose behind the city water connection is leaking. The one inside the rig. I'm pretty sure I ...
I'd strongly suggest you replace the whole fitting. The check valve in those fittings go bad and can kill a weekend trip. I carry a male end cap that I can put on it if the check valve starts to leak. When those check vales go you cant get any water pressure.
Once you repair the hose keep a close eye on it for a couple days. Nothing worse that a leak you find a couple weeks down the road!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
