DieselfiendExplorerOct 11, 2014Water LeakHi all, I'm hoping you can help me out with this problem I'm having. I've got an Arctic Fox 31D and the hose behind the city water connection is leaking. The one inside the rig. I'm pretty sure I ...Show More
DieselfiendExplorerOct 12, 2014Is the brass piece in the middle the check valve? Or is it the plastic fitting aft of it?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
Related ContentWater Heater Leak on start up.Water leakLeaking fresh water tankWater PumpFunny water pump leak
