mkirsch
Dec 07, 2016Nomad II
If the anode rod is bad, your water heater will leak.
Check what the others have suggested so far. After that it's either the element or the thermostat. Both are an easy fix on a residential water heater, and you may as well change both if they are not terribly expensive.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
