Old-Biscuit
Dec 07, 2016Explorer III
ksg5000 wrote:
Some rigs come with a mixing valve and when that gets gunked up your water temp can go haywire - worth a look.
Atwood XT model.....OP has a Suburban
OP
Suburban SW6DE is an 'electric' AND propane water heater.
Electronic Ignition for propane
As suggested: Warm Water
*Inside/outside showers not tuned off vi hot/cold knobs just with button on handle.....hot/cold can mix
*Water heater 'Bypass' valve not fully closed/leaking thru.....hot/cold can mix
OR
T-stat for electric heat control is not allowing full heating of water
(Set of t-stats for electric and propane under top cover (Push to Reset)
Left side is for electric (black wires) Right side for propane (Red wires)
Anode rod...drain plug has nothing to do with heating abilities
It protects steel tank from corosion
Electric heat element (1400W 120V AC element) either work or don't work. 120V AC current flows thru and cause element to get hot.
If bad then no current flow....no getting hot.....COLD water not Warm water
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
