wa8yxm
Dec 08, 2016Explorer III
ice2fire wrote:
Has the electric rod corroded maybe ? Or the rod you can take out got too covered with "stuff"
Thanks for any suggestions.
NO, that is not possible. though the T-Stat could have gone bad and in AZ a good chance the Node rod is in need of replacement but the Anode would not affect temp. If the heat element was that corrorded, it would not work at all.
I see the the #1 Cause (Shower mixer valves open, shower head in "Cut off" position) has been covered.
Option 2 is the bypass if you have a 3 valve system, or a one valve partially turned.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
