lanerd
Mar 20, 2014Explorer II
In both these cases, should be sufficient. However, it would seem that a ladder is required. With my method, I just use my awning rod and from the ground loop the rope over the slide out and then tie the two ends together under the slide and the slide out is still protected by the awning. Very easy and quick to do and doesn't require a ladder, or any other method to get up to the top of the slide out.
Ron
Ron
