jlscjs
Mar 20, 2014Explorer
lanerd wrote:
In both these cases, should be sufficient. However, it would seem that a ladder is required. With my method, I just use my awning rod and from the ground loop the rope over the slide out and then tie the two ends together under the slide and the slide out is still protected by the awning. Very easy and quick to do and doesn't require a ladder, or any other method to get up to the top of the slide out.
Ron
so you basically making a loop around the whole slide out and the water follows the rope and drips to the ground? Nylon or cotton rope? So how does it drain the water off exactly?
