jlscjs's avatar
jlscjs
water pooling on my slideout awning
Is there anything I can buy or make to get the water to run off of my slideout awnings? The larger one over the living room slide want to hold water all the time and I need a way to keep it from pooling.
  • Artum Snowbird wrote:
    Inflate a balloon then tie two pieces of light rope to it. Throw the rope across under the slide awning, then pull the balloon into place and lightly tie down the ropes so it stays there until you pull the slide in again.
    How do you throw the rope (across) under the awning....it's 10'+ off the ground and 18' long!
    Ron
  • Inflate a balloon then tie two pieces of light rope to it. Throw the rope across under the slide awning, then pull the balloon into place and lightly tie down the ropes so it stays there until you pull the slide in again.
  • I just wrap a small cotton rope around each of my slides and it creates a run off channel on the topper. Simple.
    Ron
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
