Loren_Ross's avatar
Loren_Ross
Water Pressure and Vent Issues
Our unit is 6 years old, and water pressure is getting very low. My gauge is showing 80# at the source, but inside the rig I have only about 30#. I can hold my hand over the faucet on full, and can hold the water flow. I've noticed a white crusty build-up on the inside of my outside hose connection and have scraped it off with a small screw driver, but I'm concerned that I may have this build-up throughout the system. Any suggestions on what I can use to flush the crud?
I also have no air vent from the gray tank. When I drain, the water will completely back up inside the drain hose and after almost 2 minutes, it will suddenly begin making a sucking sound and flowing again. I think it is building up so much pressure, it's sucking the P-trap in the shower dry to get air flowing. It has done this pretty much since it was new, but I never realized what was happening until recently when I noticed the smell coming from the shower drain when it had no water in it. I've tried to track the piping to see where it goes, but I cannot determine the path of the pipes. Suggestions on how to fix the vent?
Thanks in advance!
Loren
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 12, 2025
