hohiso's avatar
hohiso
Water Pressure Regulator - Two Questions
Finally bought a 'real' pressure regulator that has a gage and is adjustable. The gage is oil filled and directions are to keep it upright when in use. Straight up and down is not possible with direct connection to most water bibs, so the question is how upright is upright? Does the vent on top of the gage have to stay above the air bubble visible below it, or can it be above the oil?
Next question...for those of you who can adjust your water pressure...how high do you set it? My owners manual says not to exceed 45 psi or the warranty is void. Warranty is out of date and manufacturer is out of business so that doesn't matter anymore. Question is what is a practical safe upper limit?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
