sealevel_ram's avatar
sealevel_ram
Water Pump Accumulator Setting
I have an 04 Winnebago Ultimate Freedom with a Shurflow 4005 water pump that is giving me some problems. It won't shut off. System works fine on city water and I see no leaks.
What should be the pressure setting on the accumulator tank? I think this could be my the issue.
Thanks.
  • Did you try adjusting the cutoff switch on the pump?
  • Bobbo's avatar
    Bobbo
    Explorer III
    The pressure setting on an accumulator tank should be just barely above the cut-on pressure of the pump. That way the accumulator tank will empty before the pump cuts on.
    However, the accumulator tank setting can not be why your pump won't shut off. When the tank gets full, the pressure will go up to shut off the pump regardless of any settings.
    Now, if you are actually talking about the bypass setting on the pump, disregard my post. My post only applies to actual accumulator tanks.
    If the pump bypass setting is set too low, the pump will never turn off.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
