Boon_Docker
Sep 03, 2020Explorer III
The reason for the louder pump is the hot water system is somehow restricted compared to the cold water causing the pump to work harder. That draws more amps causing the lights to flicker because of the weak battery.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
