wa8yxm
Jul 21, 2018Explorer III
I finally found mine. Water heater drain on my Atwood is modified.. CPVC to Brass (Plastic to the tank and to a valve( the joint between teh Adapter and the valve was leaking.. Only took me a year to find it :). Tightened that and the dang CPVC pipe sprung a leak. Went to hardware and got a nipple (same as the ones on the inlet/outlet) got 2 different lengths 59 and 69 Cents (Cheaper to get both than to return to hardware) Used the 69 Cent one on the water heater.
Finally got my bathroom re-do done. Needed a short nipple of that too. so I used the 59 cent one as well. New toilet has the original plumbing to where the original valve was. then the nipple and a 1/2 IPT to 3/8 compression right angle cut off valve (common for house toilet installs) then a flex line to the 1/2 IPT fitting on the toilet (Also common in house installs) works great.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
