Old-Biscuit
Jan 15, 2018Explorer III
Lakejumper wrote:
Old Biscuit, it is a Shurflo 4008-1. I was proactive when this issue started a couple of trips ago and I purchased a new pump. I have replaced one in another RV before so I may try to do this one. The only problem is that this pump is very difficult to reach as it is screwed against the back panel in the utility compartment. I also heard that the pump has an adjustment screw on it and I don't know how to adjust it.
That pump has TWO adjustment screws
One for start/stop pressure setting
One for the internal bypass pressure setting
Internal bypass allows for pump to continue to run when there is low flow demand (older style pumps would start/stop during low flow demands)
Normally you would need to have a pressure gauge on RV cold water line so that you could make adjustments.
Start/Stop pressure switch would be set for 55 PSI
Bypass setting would be for 62 psi
BUT you can do an 'on the fly' setting for each
Instructions with pictures
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
