Anyone have a clue as to why I am blowing the fuse on my water pump. Replaced it and immediately blew it again. Camper has been in storage for a month, pulled out to winterize and found the fuse was b...
You may have a problem with the pump controller if equipped. Disconnect the pump, then test the system. If it blows locate the pump controller. Pump controllers of various type are used with switches to turn pump on or off from different locations.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
