TbonezExplorerNov 15, 2014Water Pump FuseAnyone have a clue as to why I am blowing the fuse on my water pump. Replaced it and immediately blew it again. Camper has been in storage for a month, pulled out to winterize and found the fuse was b...Show More
Old-BiscuitExplorer IIINov 15, 2014Pump controller IF you have multiple ON/OFF switches for pumpBut if you have just 1 ON/OFF switch for pump....then motor is shorted OR the wire from DC Dist Panel to pump is shorting out.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
Related ContentWater PumpFuse panel locateWater pumpWater Pump Failure Traveling To The Eclipsewater pump
