SoundGuy
Mar 29, 2018Explorer
teeznu wrote:
Please share your thoughts.
A city water check valve that's not sealing properly (a common problem) can leak air into the system after the pump, causing the pump to run when it shouldn't or surge when it does run. Capping that city water inlet with a threaded plug will establish whether this is your issue, or not.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
