Hurricaner
Mar 29, 2018Explorer
SoundGuy wrote:If the city check valve is leaking you will leak water not air as it is on the pump discharge. Air in the suction is always a problem, if you have a fill valve, turn that on and let the pump circulate for a minute or so. My pump seems to always get air in it after a tank fill.teeznu wrote:
Please share your thoughts.
A city water check valve that's not sealing properly (a common problem) can leak air into the system after the pump, causing the pump to run when it shouldn't or surge when it does run. Capping that city water inlet with a threaded plug will establish whether this is your issue, or not.
Sam
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
